March 17, 2023 at 1:11 pm
SolutionParticipantThis document will present the License File nomenclature in order to understand its content. It is valid for any release of ANSYS Licensing based on the FLEXlm technology.
1. 2022.R1_ANSYS_Licensing-Server-LicenseFileFormat-2067450.pdf
