ANSYS Licensing 2022.R1 How to release manually an increment (valid for any release using the FLEXlm technology).
March 17, 2023 at 1:11 pm
SolutionParticipantThis document will present the way to release manually an increment from a Client machine. The screenshots will be displaying ANSYS release 2022.R1 but the method is valid for all ANSYS releases based in FLEXlm technology.
1. 2022.R1_ANSYS_Licensing-LMREMOVE-2067405.pdf
