March 17, 2023 at 1:11 pm
SolutionParticipantThis document will present the way to create a FLEXlm Options file in the License Server machine. This file will help to manage the content of the licensing pool. This method is valid for any release of ANSYS Licensing.
1. 2022.R1_ANSYS_Licensing-Server-FLEXlm_Options_file-2067408.pdf
