March 17, 2023 at 1:11 pm
Solution
ParticipantThis document will present the way to borrow increments from a Client machine. The screenshots will be displaying ANSYS release 2022.R1 but the method is similar for oldest ANSYS releases. You will be able to borrow the increments using a Graphic User Interface (GUI) or using command lines based on the FLEXlm utility.
1. 2022.R1_ANSYS_Licensing-Client-Borrowing-2067407.pdf
