March 17, 2023 at 1:11 pm
SolutionParticipantThis document will present the Communication Ports involved in the ANSYS Licensing. It is valid for any release of ANSYS Licensing.
1. 2022.R1_ANSYS_Licensing-Server-Communication_ports-2067416.pdf
