March 17, 2023 at 1:11 pm
Solution
ParticipantERROR: Problems were encountered while attempting to start the following process(es): ansysli_server.exe, ansysli_monitor.exe, ansyslmd.exe Able to access Ansys license but in License Management Center it shows not running.
1. 2063883.pdf
