March 17, 2023 at 1:11 pm
SolutionParticipantCapability ProductName does not exist in the ANSYS licensing pool. No specified use or site license preferences match available products in the specified license path: where, ProductName could be Fluent Solver, Mechanical PrepPost, Explicit Dynamic, etc. See attached resolution document.
1. 2065422.pdf
