Ansys License Manager 2022R2 is not recognizing the hostid. Error in license.log “No valid hostids, exiting” while the host id is correct.
April 13, 2023 at 7:32 am
SolutionParticipantThere is a solution for this hostid issue we encountered with 22.2 that is using FNP 11.19.0.0. The issue is fixed in FNP 11.19.0.1. Replace the existing files and use the files from the attachment. You can back up the existing files by renaming to .bak. Both are located here by default – “C:Program FilesANSYS IncShared Fileslicensingwinx64”
1. 2068288.zip
