Tagged: ansys-icepak, ansys-spaceclaim, DDR, ECAD, fans, grilles, Icepak-compatible objects, snap, snapping tools
July 4, 2022 at 7:00 am
Watch & LearnParticipantThis video shows how to use the snap feature in Icepak. For the purpose of the demonstration a standard printed circuit board with typical components and objects is used. Simple operations are shown such as moving an edge to a required location after using the snapping tools in Icepak. Errors caused by gaps can also be fixed using this feature. Watch the video to learn more.
- ANSYS Icepak: Computing Metal Fraction and Thermal Conductivity of a Trace
- ANSYS SpaceClaim: How to change autosave interval
- ANSYS Icepak: How to open an Icepak tzr or an existing Icepak project in Workbench?
- ANSYS Icepak: Importing Geometry Using Libraries
- Quick Guide to HFSS Icepak Coupling
- ANSYS Icepak: Post-Processing Enhancements – Part 1
- ANSYS Icepak: Changing Materials For a PCB
- Creating Icepak-Compatible Objects in SpaceClaim
- Electrothermal Design of Power Converters for Electric Propulsion Systems – II
- Electrothermal Design of Power Converters for Electric Propulsion Systems – III
