Tagged: ansys-icepak, DDRs, ECAD, fans, grilles, heat sinks, layers, material-properties, PCBs, thermal, vias
July 4, 2022 at 7:00 am
Watch & LearnParticipantThis video shows how to create groups from objects of a PCB in ANSYS Icepak to facilitate editing operations and easily assign materials to the groups. For the purpose of this demonstration, a PCB model is used with some typical Icepak primitives, heat sinks, fans, grilles, DDRs etc. The video shows different methods to create a group from a bunch of DDR objects. Editing operations such as copy, move and delete are performed on the group. Creating a group makes it easy to assign materials and define thermal specifications, meshing levels etc., to the entire group rather than spending time doing the same for individual DDRs. Similarly, a group of fans is created. This video highlights the strengths of the modeler commands in Icepak.
- ANSYS Icepak: Computing Metal Fraction and Thermal Conductivity of a Trace
- ANSYS SpaceClaim: How to change autosave interval
- ANSYS Icepak: How to open an Icepak tzr or an existing Icepak project in Workbench?
- ANSYS Icepak: Importing Geometry Using Libraries
- Quick Guide to HFSS Icepak Coupling
- ANSYS Icepak: Post-Processing Enhancements – Part 1
- ANSYS Icepak: Changing Materials For a PCB
- Creating Icepak-Compatible Objects in SpaceClaim
- Electrothermal Design of Power Converters for Electric Propulsion Systems – II
- Electrothermal Design of Power Converters for Electric Propulsion Systems – III
