Licensing
Licensing
ANSYS Icepak 19.2 gives error LoadLibrary failed with error 87: The parameter is incorrect
    • SolutionSolution
      Participant
      AMD Catalyst (AMD Radeon graphics drivers and applications software package) created an incorrect registry entry when it was last installed. Perform these steps: 1. Search through the File system for atig6pxx.dll 2. Rename to atig6pxx.dll.bak 3. Re-launch application
      1. 2062566_solution.pdf
