July 4, 2022 at 7:00 am
Watch & LearnParticipantThe first mitigation scheme to minimize interference is demonstrated in this video which involves making changes on the PCB itself. The changes primarily include additional shielding in the form of dropping a via fence to protect the electronics, the victim WiFi radio in this case, to better isolate the antenna from electromagnetic interference. Watch the video to see how easy it is to modify a PCB design in HFSS 3D Layout.
- I got “I/O error when reading design” error message when opening an AEDT project with HFSS 3D Layout designs after a system crash. How should I proceed to recover my project?
- How to Export S-Parameters from HFSS 3D Layout/HFSS 3D Designs ?
- ANSYS HFSS: Creating 3D Components
- Error: Extracta view creation failed; extracta run failed: Create process failed with error 2: Could not find application extracta.exe.
- How to export a design from HFSS 3D Layout to HFSS 3D Classic?
- How to Set “Non-Model” Property to an Object in 3D Layout
- ANSYS HFSS: 3D Layout Cut Out Sub-design – Simulation and Post Processing
- ANSYS HFSS: 3D Layout Model from a Cadence Board File
- How to Create Bondwires in 3D Layout ?
