July 4, 2022 at 7:00 am
Watch & LearnParticipantThis tutorial demonstrates how to tune an antenna simulated with ANSYS HFSS through a two-way link with Optenni Lab, a matching circuit synthesis tool. ANSYS HFSS simulates 3-D full-wave electromagnetic fields for accurate and rapid design of high-frequency and high-speed electronic components.
- ANSYS HFSS: Designing a Dipole Antenna – Part I
- ANSYS HFSS: Designing a Dipole Antenna – Part III
- How to export far field data in ffd format and not csv or txt?
- Importing 3D Far Field results within HFSS
- ANSYS HFSS: Overview of Antenna Simulation – Part 1
- ANSYS HFSS: Antenna Synthesis from HFSS Antenna Toolkit – Part 2
- I defined a Master/Slave boundary condition for a unit cell but get the error : Matching boundary process might encounter unexpected conditions because the contact maps are ambiguous. What could be the reason?
- How to export ffd from HFSS and import it into EMIT
- What’s the meaning of Mag_E, ComplexMag_E etc?
- What does antenna pattern mean in unit cell model of a phased array antenna? How do I plot the embedded element pattern?
