Heat Transfer
Heat Transfer
Ansys Fluent: Using the Six Degrees of Freedom (Six DOF) Solver Thermal Analysis of a Radiator Using Ansys Fluent
    • Watch & LearnWatch & Learn
      Participant
      This video is designed with FSAE teams in mind. You will learn how to model radiator exchanging heat with liquid coolant using Ansys Fluent. The process of handling the conjugate heat transfer between blown air and coolant is also demonstrated. For questions and support, visit the Ansys Learning Forum at ansys.com/forum
