Tagged: .STL file, adjoint, adjoint-solver, ansys, ansys-fluent, bounding surfaces, duct, fluent, optimization, Shape Optimization
June 6, 2022 at 8:45 am
Watch & LearnParticipantThis video demonstrates how to use ANSYS Fluent’s adjoint solver to optimize the shape of an air duct within a space defined by imported bounding surfaces, improve the pressure drop and the outlet velocity uniformity, and export the improved design as an .STL file.
- Skewness in ANSYS Meshing
