June 6, 2022 at 8:45 am
Watch & LearnParticipantThis video demonstrates how to use the mapped mesh technique in ANSYS Fluent release 16.0. This technique is useful in many applications, such as automotive under-the-hood simulations, where heat transfer is an important consideration. A simple conjugate heat transfer (CHT) simulation is examined, followed by a review of the results of a real-world automotive under-the-hood example. ANSYS Fluent computational fluid dynamics CFD software includes well validated capabilities to deliver fast, accurate results for the widest range of simulations.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- Simulating Battery Pack Cooling System Using Ansys Fluent
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
