Tagged: ansys, cfd, FENSAP-ICE, fluent, Fluent Icing, icing, NACA0012 Clean Airfoil
June 6, 2022 at 8:44 am
Watch & LearnParticipantThis tutorial demonstrates how to obtain an airflow solution around a clean NACA0012 airfoil, using Fluent and Fluent Icing 2020 R2, that is suitable for icing calculations.
- Skewness in ANSYS Meshing
