June 6, 2022 at 8:45 am
Watch & LearnParticipantThis video demonstrates setting up and solving a thermo-fluids case using the Monte Carlo radiation model, a statistical radiation model in which a sample of photon’s histories are tracked through the system. With enough photon histories, a good estimate of the desired physical quantities can be obtained. This is especially suited, over other available methods, for modelling collimated beam style irradiation which is demonstrated in this video with an automotive headlamp case. Solar heat flux is given as an input and radiation is modeled through the air volume, front cover, and lens. The goal of the simulation is to predict the location of any thermal hot spots which occur from solar rays being focused through the lens of the headlamp assembly.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
