May 15, 2023 at 8:33 am
SolutionParticipantPlease refer to attachment to access the solution. Relevant only for version 10.0 Keywords: centroid, decomposition, preferences, load dataset
1. 2053141.pdf
- Skewness in ANSYS Meshing
