May 15, 2023 at 8:33 am
SolutionParticipantPlease refer to attachment to access the solution. Keywords: swirl, tumble, rotation, axis, velocity
1. 2053279.pdf
2. 2053279.zip
- Skewness in ANSYS Meshing
