April 5, 2023 at 2:33 pmFAQParticipant
The Abaqus reader for 64-bit Windows systems depends on a run-time library which might not be present. This version, or a later version, of the Visual C++ runtime libraries are required. If the Visual C++ library is not present, EnSight will remove Abaqus from the list of available readers. Microsoft Visual C++ 2008 Redistributable – x64 9.0.30729.6161
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
