Tagged: 18.1, HFSS - SYS, Installation/Licensing/Systems, licensing, Other
June 5, 2023 at 7:05 am
FAQParticipantCheck that the Environment Variable ‘LM_LICENSE_FILE’ with value 27000@
or 1055@ exists. It should not be set in the list of Environment Variables. If it is there, remove that and then try opening ANSYS Electronics Desktop.
