July 15, 2024 at 6:38 am
FAQParticipantThe new Ansys Discovery Technology Showcase Manual is available from online help.
- Includes real-world example problems to showcase the upfront simulation Discovery capabilities.
- Describes simulation methods and recommended best practices.
- Shows correlation between Explore and Refine modes of Ansys Discovery.
- Provides additional content to learn about Discovery features that you can use to create a similar simulation of your own.
Below are the problems explained in detail in the manual:
- Natural Frequency Analysis of a Printed Circuit Board
- Transformer and Cold Plate Fluid-Solid-Thermal Heat Transfer
- Engine Bracket Topology Optimization
- Butterfly Valve Flow Coefficient
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Ansys Discovery: Topology Optimization
- Discovery – Defining new material
- Discovery Quick Tip- Understanding Contour Settings
- Structural Simulation using Bolt Idealization
- How to apply bolt Pretension in ANSYS Discovery?
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery Quick Tip- How to Export to Fluent
