Tagged: AISC, Ansys Discovery, assessment, Bolt Assignment, bolt idealization, Bolted Connections, bonded contacts, bonding service limit, compression, contact review, Discovery Explore, Discovery Refine, factor of safety, fail, How To, pass, Prepare, shear, simulating bolted assemblies, strength limits, stress, structures, tensile, visulaization
May 22, 2023 at 8:57 am
FAQParticipantConnection Assesment tool
The new Connection Assessment Tool in Discovery 2023 R1 evaluates the pass, fail, or borderline status of bolts (in the Refine stage) and bonded contacts (in both Explore and Refine). The visualization of contact status is based on Factor of Safety values for shear stress and tensile stress, specified under Bonding Service Limits in the Contact Review or Contact HUDs. The Bolt Factor of Safety is computed based on a modified AISC allowable stress design.For more information, please refer the attached document which provides a step-by-step guide to Set up and Use Connection Assessment Tool in Ansys Discovery.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Discovery Quick Tip- Understanding Contour Settings
- Ansys Discovery: Topology Optimization
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Quick Tip- How to Export to Fluent
- Structural Simulation using Bolt Idealization
- Discovery Quick Tip- Applying Thermal Conductance
