June 6, 2022 at 10:54 am
Watch & LearnParticipantThis video demonstrates how to set up a conjugate heat transfer problem using multiple physics regions in ANSYS Discovery AIM 19.1. The video shows how to define the fluid flow physics region, define the thermal physics region, define the material assignments,define the boundary conditions, define the region interface, use the interface generator, generate a solution, and analyze the results.
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: How to Perform a Clean and Repair
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Shared Toplogy
- ANSYS SpaceClaim: Shared Topology
- ANSYS SpaceClaim: Imprinting Geometry
- How to move component within the assembly?
- ANSYS DesignModeler: Weld Feature
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
