May 22, 2023 at 9:43 am
FAQParticipantAnsys Discovery Activating Beta Features
Ansys Discovery 2023R1 comes with exciting Beta Features that you can explore by activating them from the setting and be an early adopter of our latest technologies in your simulation.To activate the features, you can navigate through following:
File >> Settings >> Advanced >> Beta Options
Please click on the desired beta option to activate it, once activated the feature will be highlighted in blue text. Please beware that certain features may require a restart for which you will be prompted when the feature is activated.
For more information, please refer to the help documentation Discovery Beta Features Documentation (ansys.com)
Keywords: Beta Feature, Live GX, Show fluid to fluid interactions, Non-linear contacts, Progress for modeling operations, revised file menu layout, Lightweight bodies for physics, topology optimization, subdivision modeling.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Structural Simulation using Bolt Idealization
- Discovery Quick Tip- How to Export to Fluent
- Thermal Analysis of Heat Sinks with Ansys Discovery
