June 6, 2022 at 10:54 am
Watch & LearnParticipantThis ANSYS How To video will demonstrate how to use midsurfacing in ANSYS DesignModeler to take solid parts and produce surface parts. This enables you to use shell elements instead of solid elements to achieve a faster, potentially more accurate solution. ANSYS DesignModeler software is the gateway to geometry handling for analysis with software from ANSYS. ANSYS DesignModeler has connections to all major CAD systems, allowing seamless transfer of existing data including parameters. The parameters can then be adjusted and the design updated, and any feature removal or simplification is maintained. This results in rapid turnaround of any design changes and updates. For more information, please visit ansys.com.
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: How to Perform a Clean and Repair
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Shared Toplogy
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
- ANSYS DesignModeler: Weld Feature
- How to move component within the assembly?
- ANSYS SpaceClaim: Imprinting Geometry
- ANSYS SpaceClaim: Shared Topology
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
