Tagged: acp, acp-pre, ansys-mechanical, bcs, chassis, composite, Formula Student, formula-sae, fsae, FSAE Car, Monocoque, roll-cage, Student Team
June 6, 2022 at 9:30 am
Watch & LearnParticipantIn this video, you will learn to visualize the ply layers through section cuts in ANSYS Composite PrepPost and apply the boundary condition for torsional analysis using ANSYS Mechanical. For any questions and support, join the ANSYS Student Community: https://studentcommunity.ansys.com/
