June 6, 2022 at 10:54 am
Watch & LearnParticipantThis video demonstrates how to calculate thermal stress from a fluid-solid heat transfer solution in ANSYS AIM. The fluid-solid heat transfer and structure simulations are solved separately. Temperature data is transferred from the solved fluid-solid heat transfer simulation into the structural simulation using the physics coupling interface. For the initial setup of the simulation, see the ANSYS AIM: Fluid-Solid Heat Transfer video (https://www.youtube.com/watch?v=ClHQo2ZaBE4). ANSYS AIM provides easy simulation software for design engineering in an integrated multiphysics simulation environment.
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: How to Perform a Clean and Repair
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Shared Toplogy
- ANSYS SpaceClaim: Shared Topology
- ANSYS SpaceClaim: Imprinting Geometry
- How to move component within the assembly?
- ANSYS DesignModeler: Weld Feature
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
