June 6, 2022 at 10:54 am
Watch & LearnParticipantIn this video you’ll learn how to set up and solve a polymer extrusion problem in ANSYS AIM. For this particular example, we’ll examine the flow of a polymer melt as it is pushed, or extruded, through a three-dimensional die. As the polymer fluid is extruded out of the die, the free surface of the extrudate is exposed and begins to deform. ANSYS AIM provides easy simulation software for design engineering in an integrated multiphysics simulation environment.
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: How to Perform a Clean and Repair
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Shared Toplogy
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
- ANSYS DesignModeler: Weld Feature
- How to move component within the assembly?
- ANSYS SpaceClaim: Imprinting Geometry
- ANSYS SpaceClaim: Shared Topology
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
