June 6, 2022 at 10:54 am
Watch & Learn
ParticipantThis video demonstrates how to set up a conjugate heat transfer problem using multiple physics regions in ANSYS AIM. The video shows how to define the fluid flow physics region, define the thermal physics region, define the material assignments, define the boundary conditions, define the region interface, use the interface generator, generate a solution, and analyze the results. ANSYS AIM provides easy simulation software for design engineering in an integrated multiphysics simulation environment.
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: How to Perform a Clean and Repair
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Shared Toplogy
- ANSYS DesignModeler: Weld Feature
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
- How to move component within the assembly?
- ANSYS SpaceClaim: Imprinting Geometry
- ANSYS SpaceClaim: Shared Topology
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
