June 6, 2022 at 10:54 am
Watch & LearnParticipantIn this video you’ll learn how to set up and solve an inverse polymer extrusion problem in ANSYS AIM where we can examine the flow of a polymer melt as it is pushed, or extruded, through a three-dimensional die. For this particular example, we’ll examine a type of simulation, called an inverse extrusion, where we determine the shape of the extrusion die based on the desired end profile shape of the extruded material. ANSYS AIM provides easy simulation software for design engineering in an integrated multiphysics simulation environment.
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: How to Perform a Clean and Repair
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Shared Toplogy
- ANSYS SpaceClaim: Shared Topology
- ANSYS SpaceClaim: Imprinting Geometry
- How to move component within the assembly?
- ANSYS DesignModeler: Weld Feature
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
