Tagged: acp, Adaption, ANSYS Composite PrepPost, composite spring, lay-up mapping, spring
June 3, 2022 at 1:43 pm
Watch & LearnParticipantThis video demonstrates the lay-up mapping capability of ANSYS Composite PrepPost (ACP) using a full cross-section composite spring. The lay-up for the model is made of 45 layers, a core, and a unidirectional roving that follows the helical shape of the spring.
ANSYS Mechanical software is a comprehensive FEA analysis (finite element) tool for structural analysis, including linear, nonlinear and dynamic studies. The engineering simulation product provides a complete set of elements behavior, material models and equation solvers for a wide range of mechanical design problems. In addition, ANSYS Mechanical offers thermal analysis and coupled-physics capabilities involving acoustic, piezoelectric, thermal-structural and thermo-electric analysis. ANSYS Mechanical Enterprise is a finite element analysis (FEA) tool that provides in-depth analysis of structural and coupled-field behavior in a highly productive environment for optimal engineering.
- Introduction to ANSYS Material Designer
- ANSYS ACP: Lay-up Mapping of a Composite Spring
- Ply Staggering with ACP – ANSYS Composite PrepPost
- Ansys Material Designer – User Defined RVEs (Representative Volume Elements)
- Variable Material Properties Calculated in Material Designer
- ANSYS Material Designer: Calculating Variable Material Properties
