January 25, 2023 at 7:34 am
FAQParticipantContact tool requires enterprise license in 2021R1 and will fail if user has no available enterprise license. This is a software bug and will be addressed in next release. A workaround is to add windows environment variable ANSYS211_PRODUCT = mech_1 or mech_2
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
