An unexpected error (Segmentation Violation ) has occurred on processor NN… ANSYS internal data has been corrupted. ANSYS is unable to recover and will terminate. Previously saved files are unaffected. FATAL error message: file1.out Check processor 0 (master) for error message(s)
January 25, 2023 at 7:28 am
FAQ
ParticipantThe issue is solved by allocating memory whilst submitting a run using ‘-m’ suffix.
- Q: How do I set the license server from my client machine?
