General
General
An MFX run fails at the start of the 1st coefficient loop, but after mesh, boundary scale, and wall scale. How can this error be resolved? Slave: 3 Slave: 3 Details of error:- Slave: 3 —————- Slave: 3 Error detected by routine PEEKCS Slave: 3 CDANAM = BCP1 /NOVARIABLES/PHYTYPE Slave: 3 CRESLT = NONE Slave: 3 Slave: 3 Current Directory : /FLOW/BOUNDCON/ZN1 Parallel run: Received message from slave —————————————– Slave partition : 3 Slave routine : ErrAction Master location : Message Handler Message label : 001100279 Message follows below – :
    • FAQFAQ
      Participant
      This is an error that was fixed in version 19.2. The workaround for previous versions is to change the mesh motion option ‘Displacement Relative To = Previous Mesh’. The Initial Mesh option which this case originally used has a problem with non-overlap fluid-structure interfaces.
