An example of using “general axisymmetric” feature to model axisymmetric geometry under non-symmetric load
March 17, 2023 at 1:11 pm
Solution
ParticipantAttached is a simple example of general axisymmetric model. The command snippet in post-process is an example of plotting result vs. circumferential angle.
1. 2059113.zip
- ANSYS Mechanical: Node Merge
- ANSYS Mechanical: Node Move
- How to use ANSYS Workbench Meshing Virtual Topology
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- What is the difference between shell 63 and shell 181?
- How to use ANSYS Workbench for Merging Mesh Nodes
