Tagged: 2022 R1, FLUENT Meshing/Tgrid, fluid-dynamics, meshing, volume mesh
April 13, 2023 at 7:32 am
Solution
ParticipantIn many cases with complex but clean solids, regular volumetric share topology (from Spaceclaim, DesignModeleer or from the mesher) may be problematic to get conformal mesh. We are resolving this problem using share topology on solids and surface enclosures/caps. Follow the pdf presentation for details.
1. 2068212.zip
2. KM_Meshing_without_volumetric_share_topology.pdf
- Skewness in ANSYS Meshing
