AIRPAK 3.0 starts fine on a Linux operating system but when starting the solver I receive the following error message: Error: Couldn’t execute “/[path]/Fluent.Inc/airpak3.0.16/filename.SCRIPT”: no such file or directory
March 17, 2023 at 9:01 am
FAQParticipantThis error message will be generated if you are using the Bash shell. Change the shell to a C shell and the problem will be resolved.
