After watertight workflow I can use Manage Zones to rename faces which are common to fluid-solid by changing prefix. Is there any TUI for the same?
Tagged: FLUENT Meshing/Tgrid, fluid-dynamics, meshing
April 13, 2023 at 7:32 am
SolutionParticipantPlease refer to attachment to access the solution. Keywords: tui, prefix, name
1. 2068117.pdf
- Skewness in ANSYS Meshing
