After specifying the virtual connections file when I click on Print Battery System Connection information, I get a warning that the positive tab has not been defined
Tagged: 17.2, fluent, fluid-dynamics, General - FLUENT, MHD/EHD
August 25, 2023 at 12:15 pm
SolutionParticipantPlease find the attached document for the solution
1. Battery_virtual_connections.pdf
- Skewness in ANSYS Meshing
