After opening a Parasolid file in SC opened through Workbench, why do I get an error when trying to open it in Meshing?
August 25, 2023 at 12:15 pm
SolutionParticipantPlease see attached document for solution. Keywords: import, parasolid, standalone
1. 2050560.pdf
- Skewness in ANSYS Meshing
