After converting a mesh to polyhedrals, layering no longer works, even if the layering zone is hexahedral.
March 17, 2023 at 1:10 pm
SolutionParticipantPlease refer to attachment to access the solution. Keywords: poly, dynamic mesh, layering
1. 2058485.pdf
- Skewness in ANSYS Meshing
