After changing a driving dimension in SCDM, the solid geometry is updated but the fluid volume created by Volume extract is not.
June 6, 2022 at 10:33 am
FAQParticipantThis is the expected behavior: Working with SpaceClaim interactively you will need to expand the corresponding Volume component in the structure tree, then right click on the Volume body and select “Update Volume Body as Created”. Alternatively, in a Workbench project, changing the corresponding parameter in the parameter manager and updating, for example, the meshing component (or design points or the whole project) will result in an automatic update of the extracted volume.
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: How to Perform a Clean and Repair
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Shared Toplogy
- ANSYS SpaceClaim: Shared Topology
- ANSYS SpaceClaim: Imprinting Geometry
- How to move component within the assembly?
- ANSYS DesignModeler: Weld Feature
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
