Tagged: ansys, ansys turbomachinery, blade flutter prediction, cfd code for turbomachinery, compressor simulation, compressor simulation software, Computational Fluid Dynamics (Field Of Study), forced response analysis, turbomachinery, turbomachinery computational fluid dynamics, turbomachinery simulation
June 6, 2022 at 8:45 am
Watch & LearnParticipantComplete simulation process to design reliable turbomachinery blades. The first step is a full Computational Fluid Dynamics (CFD) of the blade passage to to determine key performance indicators like total pressure ratio and isentropic efficiency along the entire speedline. The second step is a Multiphysics Aero-Mechanical simulation workflow to ensure that all blade natural frequencies and modes of vibration are aerodynamically damped. The third step is also a Multiphysics simulation workflow to determine the stresses caused by the unsteady flow pressure fluctuations on the blade
- Skewness in ANSYS Meshing
