March 17, 2023 at 1:11 pm
SolutionParticipantFor 2020.R2, 2021.R1 and 2021.R2, there are the different patches to be installed. This is the process to be followed : 1. Select the ANSYS release you want to patch 2. Select the correct platform 3. Download the new version of ‘ansysedt.exe’ 4. Rename the original one. For example, for 2021.R2 release and Windows machines, it will be located here : (PATH)AnsysEM21.2Win64 For example for 2021.R1 and Linux machines, it will be located here : (PATH)/AnsysEM21.1/Linux64 5. Move the one you just downloaded to the correct location. Please see attachments for the release you are running.
1. 2065607.zip
