Tagged: Ansys Discovery, control cage, editing, geometry modeling, organic, sub d, subdivided, subdivision, Surface
April 22, 2024 at 7:52 am
Watch & LearnParticipantThe Subdivision Surface tools offer a modeling technique where you can begin modeling with a basic shape having a subdivided surface. The subdivided surface is a curved limit surface represented by a coarser polygonal control cage. After creating the basic shape, you can use the various tools in the Sub-D tab to further subdivide the surfaces and add detail to form more complicated shapes.
You can also convert an existing faceted or solid model to a subdivided surface and perform editing operations to add in details as needed.
The video illustrates how you can use this feature.
For more understanding and how to use this feature with product design examples you can refer this Sub D Modeling in Ansys Discovery course.
- Surface to solid creation in SpaceClaim
- FAQ – Share Topology is now available in Discovery 2021 R2
- Split Face in SpaceClaim
- Ansys Discovery – Working with Components
- Selecting all inner faces of a body
- Changing the visibility of bodies from transparent to opaque or vice-versa
- Discovery Quick Tip- How to update your geometry from a source CAD File
- Ansys Discovery – Detect Tool
- Quick Tips for Volume extraction in SpaceClaim
- Stitch Faces & Split Edges Tools in SpaceClaim
