March 17, 2023 at 1:10 pm
SolutionParticipantObjective : Introduce the multi-objective optimization procedure for decreasing pressure loss and minimizing velocity variance using Adjoint Solver of ANSYS Fluent and automate the optimization process with ACT : Automatic Shape Optimization v2. Target : Heat Sink
1. 2054849.zip
2. 2054849_Adjoint Solver_Tutorial-2_MultiObjectiveOptimization_with_ASOv2.pdf
- Skewness in ANSYS Meshing
