Tagged: Additive Print, Desktop, General, Installation/Licensing/Systems, NA
March 17, 2023 at 9:01 am
FAQParticipantIn addition to resetting the %appdata% (refer to KM# 2054520) on how to do that. One might have to reach out to their IT group which manages Windows group policies. In some cases, It has been reported that changes to Group Policy by setting DEP – Data Execution Protection to off have helped.
