March 17, 2023 at 9:00 am
FAQParticipantYou probably have encountered one of adaptive convergence limitations. For example, You cannot use Convergence if you have an upstream or a downstream analysis link. Convergence is not supported for: A model with Layered Sections. Design Assessment. Solution Combinations. Mixed Order Meshing Orthotropic materials. Solid shell elements (the SOLSH190 series elements). If a Periodic Region or Cyclic Region symmetry object is defined. For complete list, please see ANSYS Help: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v194/wb_sim/ds_Convergence.html
